Oracle spatial layer in EPSG:3031 (Antarctic Stereographic) projection failing to publish
Key: GEOS-4038
URL: http://jira.codehaus.org/browse/GEOS-4038
Project: GeoServer
Issue Type: Bug
Components: Oracle
Affects Versions: 2.0.2
Environment: Windows XP
Geoserver 2.0.2
Tomcat 6.0
Oracle v10.2.0.4
Reporter: Alex Tate
Assignee: Andrea Aime
Attachments: coast_3031.zip
We are running into an issue when publishing an Oracle (v10.2.0.4) Spatial layer using Geoserver v2.0.2 resulting in an error message of the form...
Error persisting FeatureTypeInfoImpl[FOSSIL_MAP_TEST_2] to C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\geoserver\data\workspaces\cite\geology\FOSSIL_MAP_TEST_2\featuretype.xml
A temporary featuretype.xml.tmp gets created with the following text
<featureType>
<id>FeatureTypeInfoImpl-6b9aace9:128d9d5d3bb:-6bb8</id>
<name>FOSSIL_MAP_TEST_2</name>
<nativeName>FOSSIL_MAP_TEST</nativeName>
<namespace>
<id>NamespaceInfoImpl-4e0b98bf:12475d46fdd:-7ff4</id>
</namespace>
<title>FOSSIL_MAP_TEST_2</title>
<nativeCRS class="projected"
The Oracle table has a geometry column in EPSG:3031 projection (Antarctic Stereographic). This same table publishes and displays fine in Geoserver 1.7.2. Other spatial tables in EPSG:4326 (WGS-84) do not give the same error using v2.0.2 and the same table reprojected in various other projections works fine.
The abbreviated geoserver log shows...
2010-05-27 15:00:21,906 INFO [geoserver.web] - Error saving layer
org.geoserver.catalog.CatalogException: Error persisting FeatureTypeInfoImpl[FOSSIL_MAP_TEST_2] to C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\geoserver\data\workspaces\cite\geology\FOSSIL_MAP_TEST_2\featuretype.xml
at java.lang.Thread.run(Unknown Source)
Caused by: org.geotools.referencing.wkt.UnformattableObjectException: This "AxisDirection" object is too complex for WKT syntax.
I have also tried a shapefile (attached) in EPSG:3031 projection. While it gets through the publication process, I cannot do a map preview as it results in an error of the form...
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException>
java.lang.NullPointerException
null
</ServiceException></ServiceExceptionReport>
The same shapefile works fine in Geoserver 1.7.2. I am unsure whether the shapefile and Oracle errors are both caused by the same issue (i.e. the projection)
