[Geoserver-devel] [jira] Created: (GEOS-4045) cleaning up geoxacml community module
                 Key: GEOS-4045
                 URL: http://jira.codehaus.org/browse/GEOS-4045
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: Community
            Reporter: Lennart Jütte
            Assignee: Andrea Aime
             Fix For: Community
The geoxacml community module contains a copy of Sun's XACML implementation code (sunxacml project: http://sunxacml.sourceforge.net/). This was required, because at the time of developing the module there was a bug in Sun's code and there was no maven repository available.
This has changed now. The attached patch removes any code from sun and adds a dependency to the current SNAPSHOT-jar in sunxacml's mvn repo. In addition to that two imports of com.ibm.jvm.util.ByteArrayOutputStream are replaced with imports of java.io.ByteArrayOutputStream.
The patch has been developed for GS 2.0.2. The compatibility with trunk has to be checked (on my TODO list). AFAIK there was no development in this module, so it should work with trunk, too.
