Expecting .qix (quad-tree index) to be generated for GetMap-requests on indexed shapefile datasources with bbox<total but it's not
Key: GEOS-4054
URL: http://jira.codehaus.org/browse/GEOS-4054
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.2
Reporter: Björn Harrtell
Assignee: Andrea Aime
Fix For: 2.1.x
This seem to be caused by the ShapefileRenderer. Exact cause unknown, but I think the logic is bypassing the normal generic data source query and will only use .qix if it already exists.
WMS GetFeatureInfo will generate a .qix and I suspect that WFS-requests does too but have not tested.
Geoserver 2.1.x is not affected since it uses StreamingRenderer and a quad-tree index is generated as expected as a part of querying the generic data source.
A workaround is to force the use of streaming renderer but that's not documented.
