Error reading metadata on GeoTIFF store load
Key: GEOS-4077
URL: http://jira.codehaus.org/browse/GEOS-4077
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.2
Reporter: Jason Newmoyer
Assignee: Andrea Aime
Attachments: screenshot.jpg, stacktrace.txt
When trying to create a new store of type "GeoTIFF" I get an exception and the following error displayed in the UI -
"Could not list layers for this store, an error occurred retrieving them: Unable to acquire a reader for this coverage with format: GeoTIFF"
I am using FWTools OpenEV GDAL Export Tool to create GeoTIFFs from NOAA RNCs (http://www.charts.noaa.gov/RNCs/RNCs.shtml). About half of the resulting tiffs that I have created load perfectly and the layers render very nicely. The other half run into this error when loading the store. I have examined the metadata fields using OpenEV and the only difference I can see between the ones that work and the ones that don't is there seems to be an extra metadata field "Origin: 0 0" in the ones that don't. I have attached the stacktrace from the console and a screenshot of the export metadata fields from OpenEV.
I am using the GDAL export tool with GTiff Output Format and creation options "COMPRESS=DEFLATE,PROFILE=GeoTIFF" I have also tried different create options including PROFILE=BASELINE, no compression, COMPRESS=LZW, TILED=YES, etc.
