specifying two layers in request & cql_filter but only one in SLD results in ArrayIndexOutOfBoundsException
Key: GEOS-4080
URL: http://jira.codehaus.org/browse/GEOS-4080
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0.2
Environment: Snow Leopard, using packaged binary install.
Reporter: Carl Tashian
Assignee: Andrea Aime
I ran into an exception when I tried to create a two-layer WMS call. I started with a working request containing only cite:v_district_votes layer. When I added topp:states (and a cql_filter for topp:states) to my request, I ran into the following error.
My SLD only has one NamedLayer in it (for cite:v_district_votes), so perhaps this isn't a valid call in the first place. When I add a second NamedLayer for topp:states, the request works fine.
query
http://localhost:8080/geoserver/wms?
service=WMS
&request=GetMap
&version=1.1.1
&layers=cite:v_district_votes,topp:states
&bbox=-106.645646,25.837377,-93.5164072637683,36.500704
&cql_filter=vote_id+=+17339+and+chamber_id+=+8;STATE_ABBR=TX
&width=300
&height=300
&format=image/png
&SLD=http%3A%2F%2Flocalhost%3A3000%2Fvotes.xml
response
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException>
java.lang.ArrayIndexOutOfBoundsException: 1
1
Details:
org.geoserver.platform.ServiceException: java.lang.ArrayIndexOutOfBoundsException: 1
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1304)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:240)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 1
at org.geoserver.wms.kvp.GetMapKvpRequestReader.processLibrarySld(GetMapKvpRequestReader.java:518)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.processSld(GetMapKvpRequestReader.java:461)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:264)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:71)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1120)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:457)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:227)
... 49 more
</ServiceException></ServiceExceptionReport>
