[Geoserver-devel] [jira] Created: (GEOS-4082) GetFeatureInfo templates don't recognize ${attribute.value} notation
                 Key: GEOS-4082
                 URL: http://jira.codehaus.org/browse/GEOS-4082
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.0.2
         Environment: Windows 7, Jetty, GeoServer 2.0.2
            Reporter: Mike Pumphrey
            Assignee: Andrea Aime
            Priority: Minor
Given a layer (shapefile) with an attribute of "NAME", I should be able to create a file "[data_dir]/workspaces/[store]/[layer]/content.ftl" with the content:
${NAME.value}
And have it display the value in the GetFeatureInfo area. Alas, this doesn't happen. When clicking on a feature in the OpenLayers Layer Preview, the error at the bottom displays. I should note that I've tried both upper and lower case, and that KML GetFeatureInfo templates (title/description.ftl) work as expected.
Error:
Expression NAME is undefined on line 1, column 3 in content.ftl. The problematic instruction: ---------- ==> ${NAME.value} [on line 1, column 1 in content.ftl] ---------- Java backtrace for programmers: ---------- freemarker.core.InvalidReferenceException: Expression NAME is undefined on line 1, column 3 in content.ftl. at freemarker.core.TemplateObject.assertNonNull(TemplateObject.java:124) at freemarker.core.TemplateObject.invalidTypeException(TemplateObject.java:134) at freemarker.core.Dot._getAsTemplateModel(Dot.java:78) at freemarker.core.Expression.getAsTemplateModel(Expression.java:89) at freemarker.core.Expression.getStringValue(Expression.java:93) at freemarker.core.DollarVariable.accept(DollarVariable.java:76) at freemarker.core.Environment.visit(Environment.java:208) at freemarker.core.Environment.process(Environment.java:188) at freemarker.template.Template.process(Template.java:237) at org.vfny.geoserver.wms.responses.featureInfo.HTMLTableFeatureInfoResponse.writeTo(HTMLTableFeatureInfoResponse.java:122) at org.vfny.geoserver.wms.responses.GetFeatureInfoResponse.writeTo(GetFeatureInfoResponse.java:183) at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60) at org.geoserver.ows.Dispatcher.response(Dispatcher.java:726) at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206) at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:324) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450) java.io.IOException: Error occured processing content template content.ftl for nyc_subway_stations Error occured processing content template content.ftl for nyc_subway_stations Expression NAME is undefined on line 1, column 3 in content.ftl.
