Layer Preview uses invalid layer params
Key: GEOS-4084
URL: http://jira.codehaus.org/browse/GEOS-4084
Project: GeoServer
Issue Type: Bug
Components: UI
Affects Versions: 2.0.2
Reporter: Andreas Hocevar
Assignee: Andrea Aime
The layer preview generates layers like this:
{noformat}
tiled = new OpenLayers.Layer.WMS(
"bugsites - Tiled", "http://localhost:8001/geoserver/wms",
height: '330',
width: '938',
layers: 'base:bugsites',
styles: '',
srs: 'EPSG:26713',
format: format,
tiled: 'true',
tilesOrigin : map.maxExtent.left + ',' + map.maxExtent.bottom
buffer: 0,
displayOutsideMaxExtent: true
{noformat}
{{width}}, {{height}} and {{srs}} should be removed, because they will be overwritten by OpenLayers before a tile is requested.
The case of {{srs}} generates a non neglectable load of questions on the OpenLayers lists, because people think that if they want the layer in a different srs, they just have to change that. But what should be changed instead is the {{projection}} map option (among other map options).
