[Geoserver-devel] [jira] Created: (GEOS-4096) FID is not unique but randomly generated by Geoserver
                 Key: GEOS-4096
                 URL: http://jira.codehaus.org/browse/GEOS-4096
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration, PostGIS, WFS
    Affects Versions: 2.0.1
            Reporter: stevan pavlicic
            Assignee: Justin Deoliveira
            Priority: Blocker
             Fix For: 1.7.x
In Geoserver 1.7.5 it is possible to create a layer with unique FIDs based on a view in PostGIS. The only thing you have to do is to name a column, in that view as FID,GID or OID and make sure the values are unique.
In Geoserver 2.0.1 this doesnt work anymore.
Can this be fixed? This feature in Geoserver 1.7.5 is being exstensivly used by us and after upgrading to Geoserver 2.0.1 we cant work with views anymore. This has a serious impact on our GIS systems.
