Serving KML - Console log shows "ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks"
Key: GEOS-4097
URL: http://jira.codehaus.org/browse/GEOS-4097
Project: GeoServer
Issue Type: Bug
Components: Google Earth KML Output
Affects Versions: 2.1.x
Environment: Windows, nightly build 2.1 snapshot, -DADVANCED_PROJECTION_HANDLING=true -DUSE_STREAMING_RENDERER=true
Reporter: Phil Scadden
Assignee: Andrea Aime
Fix For: 2.1.x
If I use geoserver nightly build 2.1 snapshot, to serve KML (eg by layer
preview), then I get
showing up in the server console log. There show with every zoom and
pan, and then get outofmemory error after a while.
Openlayers client doesnt cause this problem.Reproduces with topp:tasmania_roads, layer preview, KML, from the demo data set.
