[Geoserver-devel] [jira] Created: (GEOS-4099) CSS Module doesn't always encode filters into SLD
                 Key: GEOS-4099
                 URL: http://jira.codehaus.org/browse/GEOS-4099
             Project: GeoServer
          Issue Type: Bug
            Reporter: David Winslow
            Assignee: Andrea Aime
Here's the outline of the CSS (stripped the details since I'm guessing
they aren't relevant):
{code}
/* @title 5011 - motorvag */
[KKOD = 5011] {
/* @title motorvag-text */
[KKOD = 5011][@scale<3000000] {
label: [VAGNR1];
/* @title 5213 - allman vag */
[KKOD = 5213][@scale<2000000] {
/* @title allman vag-text */
[KKOD = 5213][@scale<500000] {
label: [VAGNR1];
{code}
What I want to accomplish is:
* KKOD 5011 should always be shown
* Labels for KKOD 5011 should be shown if scale is less than 3,000,000
* KKOD 5213 should be should if scale is less than 2,000,000
* Labels for KKOD 5213 should be shown if scale is less than 500,000
But this CSS is turned into an SLD which shows *all* roads, regardless
of KKOD, at scales lower than 2,000,000 but rendered as if they had
KKOD 5213.
