Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-41
Here is an overview of the issue:
Key: GEOS-41
Summary: Automatic schema generation fails
Type: Bug
Status: Open
Priority: Minor
Original Estimate: 1 day
Time Spent: Unknown
Remaining: 1 day
Project: GeoServer
Components:
Configuration
Versions:
1.1.0
Assignee: Chris Holmes
Reporter: Thijs Brentjens
Created: Fri, 9 Jan 2004 7:46 AM
Updated: Fri, 9 Jan 2004 7:46 AM
Environment: Oracle database
Description:
Leaving out the schema.xml file should make GeoServer generate a schema automatically for the featureType. But when executing the DescribeFeatureRequest, an error is thrown. It seems to be that the geometry is not supported.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
