[Geoserver-devel] [jira] Created: (GEOS-4102) Really cache feature type attributes in resource pool
                 Key: GEOS-4102
                 URL: http://jira.codehaus.org/browse/GEOS-4102
             Project: GeoServer
          Issue Type: Improvement
          Components: Configuration
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 2.1.x
         Attachments: GEOS-4102.patch
The resource pool contains a feature attribute cache that is not really in use (there is a TODO in the code).
The current code however calls directly for the attributes when building a feature source, so caching them has become critical.
The small patch attached enables effective caching, avoiding a scan of the data directory for the schema file every single time a feature source is build (e.g., for every request)
