When use SQL Layer it possible to execute "delete from myTable" query
Key: GEOS-4134
URL: http://jira.codehaus.org/browse/GEOS-4134
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 2.1-beta1
Environment: Geoserver 2.1-beta1
jdk 1.6-u20
windows server 2003
Reporter: Lazarev Eugene
Assignee: Justin Deoliveira
this feature has very big leak. if we enter "delete from myTable" in query window, it will be delete all table data. i think the better way is always use views and tables. this method will ensure security and protect data.
another problem that is this feature isn't geoserver abstraction architecture level, this should be in database level.
so i think we must move this function to additional plugin group not in release, and of cause fix this problem with non-select queries.
