Build failure in wms
Key: GEOS-4137
URL: http://jira.codehaus.org/browse/GEOS-4137
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.1.x
Environment: Apache Maven 2.2.1 (r801777; 2009-08-07 03:16:01+0800)
Java version: 1.5.0_22
Java home: /home/car605/junk/java/jdk1.5.0_22.i586/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux" version: "2.6.32.21-166.fc12.x86_64" arch: "i386" Family: "unix"
Reporter: Ben Caradoc-Davies
Assignee: Gabriel Roldán
Priority: Blocker
Gabriel, you recent WMS changes broke trunk. This build is at r14845. Got more to come?
{code}
[INFO] Building Web Map Service Module
[INFO] Deleting directory /home/car605/geoserver/src with spaces/geoserver-trunk/src/wms/target
[INFO] Copying 12 resources
[INFO] Copying 1 resource
[INFO] Compiling 152 source files to /home/car605/geoserver/src with spaces/geoserver-trunk/src/wms/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/car605/geoserver/src with spaces/geoserver-trunk/src/wms/src/main/java/org/geoserver/wms/map/MetatileMapProducer.java:[31,0] 'class' or 'interface' expected
{code}
