[Geoserver-devel] [jira] Created: (GEOS-4144) Reverse Proxy Filter not compatible with GZIP Compression Filter
                 Key: GEOS-4144
                 URL: http://jira.codehaus.org/browse/GEOS-4144
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0.2
         Environment: windows 2003, java 1.6, Tomcat 6.0.14
            Reporter: fred w.
            Assignee: Andrea Aime
            Priority: Minor
After turning on Reverse Proxy Filter, the XML responses such as those GML links in Layer Preview failed to render. I have to remove string "text/.*,.*xml.*," from compressed-types param of GZIP Compression Filter in order to get it to work. It appears that r-proxy filter tampered XML GZIP output stream despite XML mime-type is excluded from r-proxy filter by default.
