rename Demos to Tools and make tools securable
Key: GEOS-4150
URL: http://jira.codehaus.org/browse/GEOS-4150
Project: GeoServer
Issue Type: Improvement
Components: Wicket UI
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
Fix For: 2.1-beta2
Demos is sort of a misnomer as the real use of this extension point is random useful tools. Also it makes sense based on the nature of the tool to allow only the admin access to it. The changes should be 100% backward compatible with any existing DemoLink extensions.
