Modify service code to prevent singletons from holding direct references to ServiceInfo objects
Key: GEOS-4152
URL: http://jira.codehaus.org/browse/GEOS-4152
Project: GeoServer
Issue Type: Improvement
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
Fix For: 2.1-beta2
Currently there are many singletons at the service level that obtain a reference to a WFSInfo or WCSInfo object and hold onto it for there life time. With the in memory implementation of the config that is fine but when moving to a db backed catalog that will not work because the object soon becomes stale and does not reflect configuration changes. Instead these singletons need to look the object up on demand.
