LinePlacement for labeling ignored
Key: GEOS-416
URL: http://jira.codehaus.org/browse/GEOS-416
Project: GeoServer
Type: Bug
Reporter: dblasby
Assigned to: dblasby
Fix For: 1.3.0
(this is a geotools issue)
I was attempting to write documentation for label placement (plus fix all the inconsistencies with the spec), and I noticed some problems with the SLDStyleFactory and TextStyle2D.
It turns out the SLDStyleFactory is actually trying to do [poor] label placement (see around line 570)! This also results in a loss of information if you're using a <LinePlacement> element in your SLD.
1. remove the placement code from SLDStyleFactory!
2. get rid of the "AbsoluteLineDisplacement" stuff and replace it with something that represents <PointPlacement>/<LinePlacement> elements in the TextSymbolizer.
The current implementation seems to try to convert a <LinePlacement> and a line into a <PointPlacement> (and setting the AbsoluteLineDisplacement flag)!! This should be done by the real labeling code.
This change could affect the j2d renderer as it appears to use the "AbsoluteLineDisplacement" flag.
dave
For more information on JIRA, see:
