Minimal GWC UI to configure the basics of integration with GeoServer
Key: GEOS-4161
URL: http://jira.codehaus.org/browse/GEOS-4161
Project: GeoServer
Issue Type: Sub-task
Components: GWC, Wicket UI
Affects Versions: 2.1-beta1
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.1-beta2
The other GWC integration tasks in this group need to at least be configurable as they need to be enabled/disabled.
Since right now the only mention to GWC in the configuration UI is a link to the raw GWC form, we'll need to keep a link to that form while at the same time being able to:
- enable/disable WMS integration
- enable/disable disk quota limits
- set a global disk quota limit
(there's a _lot_ more that can be done, but this is _just_ a _short term_ start)
