[Geoserver-devel] [jira] Created: (GEOS-4165) Error creating bounding box on SQL Server 2008 table with null geometry values
                 Key: GEOS-4165
                 URL: http://jira.codehaus.org/browse/GEOS-4165
             Project: GeoServer
          Issue Type: Bug
          Components: SQLServer
    Affects Versions: 2.0.2
         Environment: Geoserver 2.0.x (nightly snapshot from 7/10). Windows Server 2003 (32 bit), Tomcat 6.0.20, jre-6u21-windows.
            Reporter: James Kelly
            Assignee: Andrea Aime
         Attachments: createTesterTableAndFill.sql
This one is pretty simple to replicate.
I have added the SQL file to repeat the error.
If you have null values in the geometry column within a sql server 2008 table, when you try to add this as a feature and get the bounding box (compute from data button) you get the following error in geoserver:
ava.lang.RuntimeException: java.lang.NullPointerException
  at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:484)
  at org.geotools.jdbc.JDBCFeatureStore.getBoundsInternal(JDBCFeatureStore.java:178)
  at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:366)
  at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:338)
  at org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:526)
  at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:460)
  at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:123)
  at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:94)
  at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:128)
  at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
  at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
  at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:104)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1239)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:532)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
  at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
  at com.vividsolutions.jts.geom.Envelope.expandToInclude(Envelope.java:444)
  at org.geotools.geometry.jts.ReferencedEnvelope.expandToInclude(ReferencedEnvelope.java:528)
  at org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:1041)
  at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:477)
  ... 75 more
