CQL filter could not parce - Cyrillic data from attribute table of SHP file
Key: GEOS-4177
URL: http://jira.codehaus.org/browse/GEOS-4177
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1-beta1
Environment: Windows XP, GeoServer 2.1-beta1
Reporter: Stefan
Assignee: Andrea Aime
Priority: Critical
Attachments: correct.JPG, error.JPG
I installed GeoServer 2.1-beta1.
I publish one shp file with attribute table that contain Cyrillic and Latin letter.
I have problem with CQL filter. I describe situation below:
In attachment/correct.JPG/ - when I filer data from field with Latin letters or numerical -> Filter work correctly.
! BUT /see attachment - error.JPG/ when I try to filter data from filed name that is in Cyrillic or data in column are in Cyrillic, I receive error "Could not parse CQL filter list. Lexical error at line 1, column 1. Encountered : "\u041d"(1053), after Parsing: Номер_на_и=0.10.
How can I solve this problem? In web page attributes are displated correct. Problem is with CQL filter. I publish shp file with: charset windows-1251
Thanks
