REST resources are not thread-safe, but shared by concurrent thread because of Spring
Key: GEOS-4179
URL: http://jira.codehaus.org/browse/GEOS-4179
Project: GeoServer
Issue Type: Bug
Components: REST
Affects Versions: 2.0.x, 2.1.x
Reporter: Martins Linde
Assignee: Andrea Aime
Priority: Critical
Restlet resources are not designed to be thread-safe (response, request are stored in fields... ), but BeanResourceFinder method findTarget:
public Resource findTarget(Request request, Response response){
Resource res = (Resource) applicationContext.getBean(getBeanToFind());
res.init(getContext(), request, response);
return res;
returns the same Resource instance to concurrent threads (Spring returns the same instance),
workaround is to tell Spring to give different instances, that can be done with scope="prototype" like:
<bean id="xResource" class="x.xResource" scope="prototype"/>
But it would be nice if it could be fixed in code not in the Spring configuration file, because users may forget to add scope attribute, which may lead to real time errors.
