GetFeature without INFO_FORMAT specified only returns features from first layer
Key: GEOS-4181
URL: http://jira.codehaus.org/browse/GEOS-4181
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.1-beta1
Reporter: Eli Miller
Assignee: Andrea Aime
The output for GetFeatureInfo is incomplete if INFO_FORMAT is not specified (only features from the first layer are output). For example, if I request:
I get the following output:
Results for FeatureType 'fixed_pg_layer_19':
value = 2.00000
label = XXX55827
feature = [GEOMETRY (MultiPolygon) with 7589 points]
If I request:
I get something like this:
<gml:featureMember>
<gisws:fixed_pg_layer_19 fid="fixed_pg_layer_19.fid-4b72e5ae_12bb0771c36_-7ff9">
</gml:featureMember>
<gml:featureMember>
<gisws:pg_layer_19 fid="pg_layer_19.fid-4b72e5ae_12bb0771c36_-7ff8">
I assume that the text-based output should output the same features as the XML format output.
My examples for this are coming from a spatial database so I can't provide a simple example. If there are any problems reproducing this please let me know and I will try to create a self-contained example.
