SVG-Batik rendering fails by markers
Key: GEOS-4193
URL: http://jira.codehaus.org/browse/GEOS-4193
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0.2
Environment: WAS 6.1 on Windows.
Client works with Adobe SVG plugin on IE7
Reporter: Jeroen Klaassen
Assignee: Andrea Aime
Attachments: ErrorClientSide.jpg, punt.sld, stacktraceGeoserver.txt
We want to migrate Geoserver from version 1.7.5 to 2.0.2.
However we find a problem with the rendering of SVG after we load an image as pointsymbolizer.
We got the message as shown in the attachement ErrorClientSide.jgp
The Geoserver logging is attached as stacktraceGeoserver.txt
The used sld is also included as attachment punt.sld
When we downgrade Batik 1.7 to 1.6 the problem seems to be solved.
This causes an other problem.
We now get array index out of range for large amount of data.
We also tried the nightly build from 11 october 2010. The same problem occours there.
