[Geoserver-devel] [jira] Created: (GEOS-4199) Improve shapefile output traceability and flexibility
                 Key: GEOS-4199
                 URL: http://jira.codehaus.org/browse/GEOS-4199
             Project: GeoServer
          Issue Type: Improvement
          Components: WFS
    Affects Versions: 2.1-beta1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.0.3
Make the shape-zip output format more traceable:
- allow the admin to customize the resulting zip name
- allow the admin to customize the single shapefile name
- add a file containing a dump of the request (whose name has to be customizable as well)
Use a single freemarker template, with a property file structure, to specify and customize all the above.
The current naming scheme should remain unaltered by default
