Error when querying data from SQL (com.vividsolutions.jts.io.ParseException: Expected number but found '(' )
Key: GEOS-4205
URL: http://jira.codehaus.org/browse/GEOS-4205
Project: GeoServer
Issue Type: Bug
Components: SQLServer
Affects Versions: 2.1-beta1
Environment: gt-jdbc-sqlserver-2.7-SNAPSHOT.jar (revision 36307)
sqljdbc4.jar
SQL Server 2008 R2
Java 1.6
Windows 2003
Reporter: Lazarev Eugene
Assignee: Andrea Aime
Attachments: 000F000006D6.sql, 2010_11_01.request.log, wrapper.log
when trying to render layer there are an error
Caused by: com.vividsolutions.jts.io.ParseException: Expected number but found '('
at com.vividsolutions.jts.io.WKTReader.parseError(WKTReader.java:383)
at com.vividsolutions.jts.io.WKTReader.getNextNumber(WKTReader.java:281)
at com.vividsolutions.jts.io.WKTReader.getPreciseCoordinate(WKTReader.java:235)
at com.vividsolutions.jts.io.WKTReader.getCoordinates(WKTReader.java:221)
at com.vividsolutions.jts.io.WKTReader.readMultiPointText(WKTReader.java:517)
at com.vividsolutions.jts.io.WKTReader.readGeometryTaggedText(WKTReader.java:440)
at com.vividsolutions.jts.io.WKTReader.read(WKTReader.java:194)
at com.vividsolutions.jts.io.WKTReader.read(WKTReader.java:163)
at org.geotools.data.sqlserver.SQLServerDialect.decodeGeometry(SQLServerDialect.java:232)
it is very strange because data stores in geometry column and if we suppose wrong data, so it can't be stored in table when inserted
other layers that stored similar render great.
this is occurs also in WFS queries
you can try data in test server http://svn.ugi.ru:1580/geoserver
Login admin
Pass geoserver
