Can't create connection to remote data store (ArcSDE)
Key: GEOS-4220
URL: http://jira.codehaus.org/browse/GEOS-4220
Project: GeoServer
Issue Type: Bug
Components: ArcSDE
Environment: Ubuntu 10.04.1, Tomcat 6.0.29, GeoServer GeoNode dev snapshot,
Java(TM) SE Runtime Environment (build 1.6.0_22-b04)
Java HotSpot(TM) 64-Bit Server VM (build 17.1-b03, mixed mode)
Reporter: Christian Spanring
Assignee: Andrea Aime
* data store (remote ArcSDE server) was working fine
* Applied some JVM configuration hints as described in http://opengeo.org/publications/geoserver-production/
* restarted Tomcat and GeoServer won't connect to ArcSDE server anymore
* verified that ArcSDE server is accessible from GeoServer instance (e.g. successful ping)
* data store on same machine as GeoServer (PostGIS) works fine
Trying to access an ArcSDE layer in GeoServer brings up the "Oops, something went wrong..." page with following output:
org.apache.wicket.WicketRuntimeException: java.io.IOException: Can't create connection to 10.10.10.237 for Session #6 at org.geoserver.web.data.resource.FeatureResourceConfigurationPanel$1.getObject(FeatureResourceConfigurationPanel.java:46) at org.apache.wicket.Component.getModelObject(Component.java:1565) at org.apache.wicket.markup.html.list.ListView.getViewSize(ListView.java:217) at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:524) at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:127) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:147) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.addedComponent(MarkupContainer.java:913) at org.apache.wicket.MarkupContainer.add(MarkupContainer.java:139) at org.apache.wicket.extensions.markup.html.tabs.TabbedPanel.setSelectedTab(TabbedPanel.java:334) at org.apache.wicket.extensions.markup.html.tabs.TabbedPanel.onBeforeRender(TabbedPanel.java:209) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590) at org.apache.wicket.Component.onBeforeRender(Component.java:3727) at org.apache.wicket.Page.onBeforeRender(Page.java:1458) at org.apache.wicket.Component.internalBeforeRender(Component.java:1009) at org.apache.wicket.Component.beforeRender(Component.java:1041) at org.apache.wicket.Component.prepareForRender(Component.java:2167) at org.apache.wicket.Page.renderPage(Page.java:892) at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:240) at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:104) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1245) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418) at org.apache.wicket.RequestCycle.request(RequestCycle.java:532) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356) at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:124) at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:93) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Thread.java:662) Caused by: java.io.IOException: Can't create connection to 10.10.10.237 for Session #6 at org.geotools.arcsde.session.Session$CreateSeConnectionCommand.execute(Session.java:812) at org.geotools.arcsde.session.Session$CreateSeConnectionCommand.execute(Session.java:758) at org.geotools.arcsde.session.Session.issue(Session.java:263) at org.geotools.arcsde.session.Session.<init>(Session.java:246) at org.geotools.arcsde.session.SessionPool$SeConnectionFactory.makeObject(SessionPool.java:373) at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:1148) at org.geotools.arcsde.session.SessionPool.<init>(SessionPool.java:153) at org.geotools.arcsde.session.SessionPoolFactory.createPool(SessionPoolFactory.java:64) at org.geotools.arcsde.ArcSDEDataStoreFactory.createDataStore(ArcSDEDataStoreFactory.java:263) at org.geotools.arcsde.ArcSDEDataStoreFactory.createDataStore(ArcSDEDataStoreFactory.java:253) at org.geotools.arcsde.ArcSDEDataStoreFactory.createDataStore(ArcSDEDataStoreFactory.java:71) at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:107) at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:317) at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:564) at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:552) at org.geoserver.catalog.ResourcePool.loadAttributes(ResourcePool.java:440) at org.geoserver.catalog.ResourcePool.getAttributes(ResourcePool.java:418) at org.geoserver.catalog.impl.FeatureTypeInfoImpl.attributes(FeatureTypeInfoImpl.java:82) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144) at $Proxy12.attributes(Unknown Source) at org.geoserver.web.data.resource.FeatureResourceConfigurationPanel$1.getObject(FeatureResourceConfigurationPanel.java:43) ... 110 more Caused by: java.lang.IndexOutOfBoundsException at java.io.ByteArrayInputStream.read(ByteArrayInputStream.java:163) at java.io.DataInputStream.read(DataInputStream.java:132) at com.esri.sde.sdk.client.s$a_.a(Unknown Source) at com.esri.sde.sdk.client.s$a_.m(Unknown Source) at com.esri.sde.sdk.client.s$a_.b(Unknown Source) at com.esri.sde.sdk.client.s$a_.b(Unknown Source) at com.esri.sde.sdk.client.SeRelease.a(Unknown Source) at com.esri.sde.sdk.client.SeRelease.read(Unknown Source) at com.esri.sde.sdk.client.s$a_.a(Unknown Source) at com.esri.sde.sdk.client.s.a(Unknown Source) at com.esri.sde.sdk.client.b.a(Unknown Source) at com.esri.sde.sdk.client.SeConnection.w(Unknown Source) at com.esri.sde.sdk.client.SeConnection.<init>(Unknown Source) at org.geotools.arcsde.session.Session$CreateSeConnectionCommand.execute(Session.java:793) ... 134 more
