[Geoserver-devel] [jira] Created: (GEOS-4235) Non-fatal Java error during startup: javax.naming.NoInitialContextException
                 Key: GEOS-4235
                 URL: http://jira.codehaus.org/browse/GEOS-4235
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-beta1
            Reporter: Mike Pumphrey
            Assignee: Justin Deoliveira
            Priority: Minor
When starting GeoServer, the following error displays:
0 [main] WARN org.mortbay.log - Deprecated configuration used for C:\Program Files\OpenGeo\OpenGeo Suite/webapps
34384 [main] INFO org.geoserver.logging - RELINQUISH_LOG4J_CONTROL on, won't attempt to reconfigure LOG4J loggers
43368 [main] ERROR org.vfny.geoserver.global -
- GEOSERVER_DATA_DIR: C:\Users\OpenGeo\.opengeo\data_dir
43475 [main] INFO org.geoserver.config.GeoServerPropertyConfigurer - Loading properties file from URL [file:/C:/Users/OpenGeo/.opengeo/data_dir/monitoring/hibernate.properties]
51338 [main] WARN org.hibernate.impl.SessionFactoryObjectFactory - Could not bind factory to JNDI
javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial
  at javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
  at javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
  at javax.naming.InitialContext.getURLOrDefaultInitCtx(Unknown Source)
  at javax.naming.InitialContext.getNameParser(Unknown Source)
  at org.hibernate.util.NamingHelper.bind(NamingHelper.java:52)
  at org.hibernate.impl.SessionFactoryObjectFactory.addInstance(SessionFactoryObjectFactory.java:90)
  at org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:306)
  at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1300)
  at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:814)
  at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:732)
  at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1368)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1334)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
  at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:881)
  at org.geoserver.monitor.MonitorConfig.createDAO(MonitorConfig.java:63)
  at org.geoserver.monitor.Monitor.<init>(Monitor.java:36)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
  at java.lang.reflect.Constructor.newInstance(Unknown Source)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
  at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.context.support.AbstractApplicationContext.registerBeanPostProcessors(AbstractApplicationContext.java:606)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:366)
  at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
  at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
  at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
  at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
  at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
  at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
  at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
  at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
  at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
  at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
  at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
  at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
  at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
  at org.mortbay.jetty.Server.doStart(Server.java:222)
  at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.mortbay.start.Main.invokeMain(Main.java:194)
  at org.mortbay.start.Main.start(Main.java:509)
  at org.mortbay.start.Main.main(Main.java:119)
  at org.opengeo.jetty.Start.main(Start.java:80)
