Unable to add directory via relative path of rshapefiles from the shapefile datastore configuration page
Key: GEOS-4238
URL: http://jira.codehaus.org/browse/GEOS-4238
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1-beta1
Reporter: Justin Deoliveira
Assignee: Andrea Aime
Trying to add a relative path which is a directory leads to having the path resolved locally to the working directory. In the end the only work around was to point to a file with the file chooser. Then edit the datastore.xml to point to the directory.
To reproduce:
1) add some shapefiles to some directory under data
2) go to ui and add a new shapefile datastore
3) enter in file:data/ in the text box and hit submit
