Have GeoServer return proper HTTP error codes along with service exceptions
Key: GEOS-4255
URL: http://jira.codehaus.org/browse/GEOS-4255
Project: GeoServer
Issue Type: Improvement
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.1-RC1
Currently all service exceptions return with HTTP 200, whilst some variant of 400 or 500 should be used instead.
OWS 1.0 was not clear on whether to use error codes or not, so we're going to enable http error codes only if the administrator enables them for backwards compatibility.
OWS 1.1 mandates the usage of error codes in its abstract test suite, though it's not clear what codes should be used.
OWS 2 mandates error codes and also specifies which ones should be used based on the OWS error code: we are going to use this classification as a reference.
