[Geoserver-devel] [jira] Created: (GEOS-4256) oracle.sql.TIMESTAMP returned instead of java.sql.Timestamp
                 Key: GEOS-4256
                 URL: http://jira.codehaus.org/browse/GEOS-4256
             Project: GeoServer
          Issue Type: Bug
          Components: Oracle
    Affects Versions: 2.0.2
         Environment: Windows
            Reporter: steve gorman
            Assignee: Andrea Aime
When I try to publish an Oracle View that has a table of type TIMESTAMP to GeoServer the table is ignored.
CREATE TABLE "CHAT"."MESSAGE"
   ( "ID" NUMBER(10,0) NOT NULL ENABLE,
  "TIME_OVER_TARGET" TIMESTAMP (6) WITH TIME ZONE NOT NULL ENABLE,
  "MESSAGE" CLOB NOT NULL ENABLE,
  "FRAME_CENTER" "MDSYS"."SDO_GEOMETRY"....... ,
During Publish in Geoserver
10 Dec 11:53:23 WARN [geotools.jdbc] - Could not find mapping for 'TIMEOVERTARGET', ignoring the column and setting the feature type read only
According to oracle if the J2EE13Compliant flag is not set before obtaining a connection than the time will be returned as oracle.sql and not java.sql.
