[Geoserver-devel] [jira] Created: (GEOS-4258) GetFeatureInfo FEATURE_COUNT is applied per layer instead of being a global count
                 Key: GEOS-4258
                 URL: http://jira.codehaus.org/browse/GEOS-4258
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1-beta2, 2.0.2
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.1-RC1
The spec says:
{panel}
7.3.3.7 FEATURE_COUNT
The optional FEATURE_COUNT parameter states the maximum number of features for
which feature information should be returned. Its value is a positive integer greater than
zero. The default value is 1 if this parameter is omitted.
{panel}
The count is not per layer, it's global. By default at most one feature info should be returned, not one per layer
