[Geoserver-devel] [jira] Created: (GEOS-4260) Problem when renaming styles
                 Key: GEOS-4260
                 URL: http://jira.codehaus.org/browse/GEOS-4260
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1-beta2
            Reporter: Simone Giannecchini
            Assignee: Justin Deoliveira
            Priority: Minor
             Fix For: 2.1-RC1
When renaming styles it happens that if the new name is the same as the old one except for different case (e.g. burg vs BuRg) a duplicate entry
appears in the UI as well as inside the styles directory.
