GeoWebCache not publishing layer title definition
Key: GEOS-4289
URL: http://jira.codehaus.org/browse/GEOS-4289
Project: GeoServer
Issue Type: Bug
Components: GWC
Affects Versions: 2.1-beta3
Environment: Windows Server 2008
Reporter: Klaus Nji
Assignee: Andrea Aime
Priority: Minor
When a new layer is configured, its title initially defaults to its name, which often times is not a user friendly string. If you change this default title, from say "layer_name" to a user friendly string such as "Layer Title" for instance, stop and start GeoServer and GWC, you will continue to see "layer_name" returned as the layer's title when you submit a GetCapabilities request to the GWC.
However, if you submit GetCapabilities directly do GeoServer and not through the GWC, you will see the correct layer titles.
