[Geoserver-devel] [jira] Created: (GEOS-4291) enable logging about gzip compression
                 Key: GEOS-4291
                 URL: http://jira.codehaus.org/browse/GEOS-4291
             Project: GeoServer
          Issue Type: Improvement
          Components: Global
    Affects Versions: 2.1-beta3, 2.0.2
            Reporter: David Winslow
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: enable-gzip-logging.diff
The logging in the GZIP compression filter is disabled by commenting out in the code rather than using the logging level system. This patch would change that, logging whether GZIP compression is applied at the DEBUG level.
