Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-43
Here is an overview of the issue:
Key: GEOS-43
Summary: Change misc/cite/configuration.xml to services.xml and catalog.xml
Type: Task
Status: Open
Priority: Trivial
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Configuration
Fix Fors:
1.1.1
Versions:
1.1.0
Assignee: Chris Holmes
Reporter: Chris Holmes
Created: Fri, 16 Jan 2004 10:45 AM
Updated: Fri, 16 Jan 2004 10:45 AM
Description:
The cite directory to assist in setting up cite tests needs to be changed to have a sample services.xml and catalog.xml, instead of the configuration.xml that is there now.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
