can't build project with maven
Key: GEOS-4302
URL: http://jira.codehaus.org/browse/GEOS-4302
Project: GeoServer
Issue Type: Bug
Environment: Windows XP, Apache Maven 2.2.1, Java(TM) SE Runtime Environment (build 1.6.0_07-b06)
Reporter: Nikolay Izhikov
Assignee: Andrea Aime
Priority: Blocker
When I try to build trunk version of GeoServer I got following error
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver:gwc
POM Location: E:\work\OnlineSales\geoserver\sources\geoserver\src\gwc\pom.xml
Validation Messages:
[0] 'dependencies.dependency.version' is missing for org.geowebcache:gwc-diskquota:jar
Reason: Failed to validate POM for project org.geoserver:gwc at E:\work\OnlineSales\geoserver\sources\geoserver\src\gwc\pom.xml
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM for project org.geoserver:gwc at E:\work\OnlineSales\geoserver\sources\geoserver\src\gwc\pom.xml
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:404)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:272)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM for project org.geoserver:gwc at E:\work\OnlineSales\geoserver\sources\geoserver\src\gwc\pom.xml
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1077)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:880)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:508)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:200)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:604)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:487)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:560)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:391)
... 12 more
[INFO] Total time: < 1 second
