[Geoserver-devel] [jira] Created: (GEOS-4307) STYLES parameter is not set on GetFeatureInfo request for cascading layers
                 Key: GEOS-4307
                 URL: http://jira.codehaus.org/browse/GEOS-4307
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-RC1
            Reporter: Ivan Grcic
            Assignee: Andrea Aime
            Priority: Minor
Required parameter STYLES is not set if we're doing getFeatureInfo on cascading layer, so cascading server can throw ServiceException similar to one we have in geoserver:
{ServiceException={null=1 layers requested, but found 0 styles specified. Since SLD parameter is not yet implemented, the STYLES parameter is mandatory and MUST have exactly one value per requested layer, code=org.vfny.geoserver.wms.requests.GetMapKvpReader}, version=1.1.1}
It has be something with fact that we're "faking" default NamedStyle (with namedStyle.setName(null)) in case of WMSLayer, so later on style is not processed correctly.
I will investigate this more when I find little time.
Any suggestions/tips welcomed :wink:
Ivan
