RenderedImageMapOutputFormat.readBestCoverage is improperly setting readParams
Key: GEOS-4311
URL: http://jira.codehaus.org/browse/GEOS-4311
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1-RC1
Reporter: Daniele Romagnoli
Assignee: Daniele Romagnoli
Fix For: 2.1-RC2, 2.1.x
Attachments: wmsPatch_21x.patch, wmsPatch_trunk.patch
The readBestCoverage method is improperly setting the readParams for the incoming read operation, when it checks for interpolation and gridGeometry parameters.
Look at this part of code:
final int size = length + (!foundGG && !foundInterpolation ? 2:1);
GeneralParameterValue readParams2 = new GeneralParameterValue[length + size];
System.arraycopy(readParams, 0, readParams2, 0, length);
As you can see it is creating a GeneralParameterValue array with (length+size) elements whilst the "size" variable has already been computed by adding some elements to "length".
This results in having a too long array with several null parameters.
Using that simple line will fix it:
GeneralParameterValue readParams2 = new GeneralParameterValue[size];
Patches in attachment:
- wmsPatch_trunk.patch: for fixing trunk (to be applied on geoserverTrunk/src/wms subfolder)
- wmsPatch_21x.patch: for fixing 2.1.x branch (to be applied on geoserver21x/src/wms subfolder)
