WPS module gives NoApplicableCode with every request
Key: GEOS-4314
URL: http://jira.codehaus.org/browse/GEOS-4314
Project: GeoServer
Issue Type: Bug
Components: WPS
Affects Versions: 2.1-RC1
Environment: Ubuntu 10.04 64bit but I remember having seen it on Windows too.
Reporter: Roald de Wit
Assignee: Andrea Aime
Priority: Critical
With every request sent, I always get the same error back. This issue has been reported by at least one other person: http://www.mail-archive.com/geoserver-users@lists.sourceforge.net/msg02371.html
*Example request*:
{noformat}
<wps:Execute version="1.0.0" service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.opengis.net/wps/1.0.0" xmlns:wfs="http://www.opengis.net/wfs" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">
<ows:Identifier>JTS:convexHull</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>geom</ows:Identifier>
<wps:Reference mimeType="text/xml; subtype=gml/3.1.1" xlink:href="http://geoserver/wfs" method="POST">
<wps:Body>
<wfs:GetFeature service="WFS" version="1.0.0" outputFormat="GML2">
<wfs:Query typeName="topp:tasmania_roads"/>
</wfs:GetFeature>
</wps:Body>
</wps:Reference>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput mimeType="text/xml; subtype=gml/3.1.1">
<ows:Identifier>result</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
{noformat}
*Example response*:
{noformat}
<ows:ExceptionReport version="1.1.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver-21rc1/schemas/ows/1.1.0/owsAll.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>
Process returned with an exception
Could not convert net.opengis.wfs.impl.FeatureCollectionTypeImpl@anonymised.com (lockId: null, timeStamp: java.util.GregorianCalendar[time=1295522225886,areFieldsSet=true,areAllFieldsSet=true,lenient=true,zone=sun.util.calendar.ZoneInfo[id="Australia/Victoria&
feature: [org.geotools.data.crs.ForceCoordinateSystemFeatureResults@anonymised.com...]) to target type com.vividsolutions.jts.geom.Geometry
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
{noformat}
I took out some of the error for readability. The full error can be found in the log below.
*Error log*:
{noformat}
==> /usr/local/tomcat-6/logs/catalina.out <==
20 Jan 22:17:05 WARN [geotools.xml] - TargetNamespace.2: Expecting no namespace, but the schema document has a target namespace of 'http://www.opengis.net/wps/1.0.0’.
20 Jan 22:17:05 WARN [geoserver.wps] - TargetNamespace.2: Expecting no namespace, but the schema document has a target namespace of 'http://www.opengis.net/wps/1.0.0’.
20 Jan 22:17:05 ERROR [geoserver.ows] -
org.geoserver.wps.WPSException: Process returned with an exception
at org.geoserver.wps.Execute.executeInternal(Execute.java:284)
at org.geoserver.wps.Execute.run(Execute.java:119)
at org.geoserver.wps.DefaultWebProcessingService.execute(DefaultWebProcessingService.java:68)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.geotools.process.ProcessException: Could not convert net.opengis.wfs.impl.FeatureCollectionTypeImpl@anonymised.com (lockId: null, timeStamp: java.util.GregorianCalendar[time=1295522225886,areFieldsSet=true,areAllFieldsSet=true,lenient=true,zone=sun.util.calendar.ZoneInfo[id="Australia/Victoria",offset=36000000,dstSavings=3600000,useDaylight=true,transitions=142,lastRule=java.util.SimpleTimeZone[id=Australia/Victoria,offset=36000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=9,startDay=1,startDayOfWeek=1,startTime=7200000,startTimeMode=1,endMode=3,endMonth=3,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=1]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2011,MONTH=0,WEEK_OF_YEAR=4,WEEK_OF_MONTH=4,DAY_OF_MONTH=20,DAY_OF_YEAR=20,DAY_OF_WEEK=5,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=17,SECOND=5,MILLISECOND=886,ZONE_OFFSET=36000000,DST_OFFSET=3600000], numberOfFeatures: 0, feature: [org.geotools.data.crs.ForceCoordinateSystemFeatureResults@anonymised.com...]) to target type com.vividsolutions.jts.geom.Geometry
at org.geoserver.wps.jts.AnnotationDrivenProcessFactory$ProcessInvocation.execute(AnnotationDrivenProcessFactory.java:260)
at org.geoserver.wps.Execute.executeInternal(Execute.java:270)
... 124 more
{noformat}
