[Geoserver-devel] [jira] Created: (GEOS-4329) ConcurrentModificationException in GetFeature under heavy load
                 Key: GEOS-4329
                 URL: http://jira.codehaus.org/browse/GEOS-4329
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-RC1
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 2.1-RC2
Under heavy load of both GetFeature and DescribeFeatureType we get failures in GetFeature in roughly 10% of the GetFeature requests with the following stack trace:
{code}
2011-01-26 08:50:22,030 ERROR [geoserver.ows] -
java.util.ConcurrentModificationException
  at org.eclipse.emf.common.util.BasicEList$EIterator.checkModCount(BasicEList.java:1327)
  at org.eclipse.emf.common.util.BasicEList$EIterator.next(BasicEList.java:1275)
  at org.geotools.xml.Encoder.encode(Encoder.java:726)
  at org.geotools.xml.Encoder.encode(Encoder.java:563)
  at org.geoserver.wfs.xml.GML3OutputFormat.encode(GML3OutputFormat.java:253)
  at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:241)
  at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:141)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:751)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:233)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
{code}
This is probably related to the substitution group handling in gt-xsd as the problem occurrs while visiting substitution groups for _Feature.
The patches committed on GeoTools at revision 35934,35936,35937 have been beneficial in this respect, as the same test against GS 2.0.2
results in well over 90% failures instead (which do start with the same stack trace, but eventually lead to NPE as some null finds its way into
the substitution group list), but I guess it's not enough since it's still possible to reproduce failures.
I'm going to attach a JMeter script that makes the problem evident: it creates two groups of 40 threads that do run concurrently, one makes
a lot of DFT (8000, as they are quick to process), the other one some GetFeature (800).
