[Geoserver-devel] [jira] Created: (GEOS-4342) Cannot update a postgis table using WFS 1.0/1.1
                 Key: GEOS-4342
                 URL: http://jira.codehaus.org/browse/GEOS-4342
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
         Environment: Windows XP, Geoserver latest trunk, PostgreSQL 8.4
            Reporter: Zsolt Sandor
            Assignee: Andrea Aime
         Attachments: wfs-bugreport.zip
Action:
I tried to use WFS to update the coordinates of a polygon in our postgis database.
Result:
The result is either no action or an Exception/Stacktrace.
"Caused by: org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block."
Steps to reproduce:
- Install postgresql with postgis extension
- Create a table called gis_fence and wrote a single line in it (see attachment)
- Create a new datasource and layer, called gis_fence to the cite namespace.
- Run the WFS queries (wfs-update-10.txt,wfs-update-11.txt)
Geoserver log, SQL and WFS scripts are in the attachment.
Remarks:
One problem may be in JDBCDataStore class's getBounds() method, because the optimized table does not exists, an SQL is started to retrieve the data, and this is the point where the exception raises.
This SQL works from command line...
