textsymbolizers always on top of everything else?!
Key: GEOS-4352
URL: http://jira.codehaus.org/browse/GEOS-4352
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.2
Environment: windows, geoserver with postgresql & postgis
Reporter: Teresa Böttcher
Assignee: Andrea Aime
I have a small issue with SLD, specifically the order in which symbolizers (mainly the textsymbolizer) are presented/rendered.
Example:
1 layer roads with roads.sld (linesymbolizers & textsymbolizers)
1 layer POI with poi.sld (pointsymbolizers & textsymbolizers)
Both are grouped together, with the roads-layer being drawn first.
Everything seems to be according to the OGC specification and/or the GeoServer user manual, except for the textsymbolizer (of the roads.sld). These labels are ALWAYS on top of everything else. While I understand that these labels cannot "know" the specific dimension of the POI-graphics in different SLD-file, I would very much prefer the graphics to just overlap the street-labels (honoring the whole "painters-model").
(I also tried to get around this by using textsymbolizers with graphics for the POIs. But unfortunately I have a number of POIs as polygons, which do not work with the textsymbolizer. Well, text/labels work at very large scale (e.g. 1:1200), graphics don't work at all.)
Is this a bug, or just standard GeoServer behavior?
I would really appreciate any help/hints regarding this issue. Thank you.
