[Geoserver-devel] [jira] Created: (GEOS-4365) GeoServer 2.1.x User Manual Includes innacurate information regarding OpenJDK support
                 Key: GEOS-4365
                 URL: http://jira.codehaus.org/browse/GEOS-4365
             Project: GeoServer
          Issue Type: Bug
          Components: Documentation
         Environment: N/A
            Reporter: Nicholas Whittier
            Assignee: Andrea Aime
            Priority: Minor
The Java Considerations documentation (http://docs.geoserver.org/stable/en/user/production/java.html) states that OpenJDK will not work with GeoServer. This should be updated to indicate that OpenJDK will support GeoServer, but that performance will suffer.
Text: "JREs other than those released by Sun may work correctly, but are generally not tested or supported. Specifically, OpenJDK does not work with GeoServer, as it lacks sufficient support for 2D rendering."
Should read: "JREs other than those released by Sun may work correctly, but are generally not tested or supported. GeoServer will work with OpenJDK, but expect reductions in 2D rendering performance."
