[Geoserver-devel] [jira] Created: (GEOS-4367) Style modifications through restconfig do not cause a catalog event to be thrown, preventing GWC to clear the cache
                 Key: GEOS-4367
                 URL: http://jira.codehaus.org/browse/GEOS-4367
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 2.1-RC1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.1-RC2
The problem is the restconfig API is not calling Catalog.save(StyleInfo), so the Catalog is not issuing a notification event that the GWC listener can take and truncate the affected layers.
If the style is modified through the GeoServer UI though, the cache _is_ cleared for the affected layers.
The {org.geoserver.catalog.rest.StyleResource} class, instead of modifying the StyleInfo, goes under the hood making:
{code}
protected void handleObjectPut(Object object) throws Exception {
        else if ( object instanceof Style ) {
            StyleInfo s = catalog.getStyleByName( style );
            catalog.getResourcePool().writeStyle( s, (Style) object, true );
        LOGGER.info( "PUT style " + style);
{code}
which effectively causes the style to be written down to its .sld file and cleared from the ResourcePool cache, but doesn't cause the notification event to be thrown.
