Restore ThreadPoolExecutor support for multithreaded imageMosaic/imagePyramid granules loading
Key: GEOS-4370
URL: http://jira.codehaus.org/browse/GEOS-4370
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1-RC1
Reporter: Daniele Romagnoli
Assignee: Daniele Romagnoli
Fix For: 2.1-RC2, 2.2.x
During some tests, I have noticed that my previous work on supporting ImageMosaic/ImagePyramid granules multithreaded loading through a ThreadPoolExecutor (http://jira.codehaus.org/browse/GEOS-4101) is not properly working anymore. This happens in case you restart geoserver and then you try a multithreaded loading on a previously configured layer. (That capability have been provided by means of a CoverageAccess interface which you can use to configure/tune the ThreadPoolExecutor to be used as Hint for the imageMosaic/imagePyramid GridCoverageReaders. During geoserver startup, the CoverageAccessInitializer is invoked to setup the executor.)
After some investigation, I have noticed that right now there is a WMSValidator which validates configured coverages by asking for a GridCoverageReader on each raster layer. However, this step is performed before the geoserver initializers are invoked (JAIInitializer, CoverageAccessInitializer, ResourcePoolInitializer....), therefore there is no configured Executor yet and the GridCoverageReaders are cached in the ResourcePool without the proper Hint.
To restore this support, I will put a systemDefault Hint (linking to a default Executor) on the GeoserverInitStartupListener.
By this way, such a Hint will be found when asking for GridCoverageReaders during catalog validation and cached readers will make use of that executor.
Moreover, the code initializing the CoverageAccess will look for the Executor within Hints and then it will adjust the parameters (keepAliveTime, poolSize) by parsing the configuration.
