[Geoserver-devel] [jira] Created: (GEOS-4386) Demo Requests not executable outside firewall
                 Key: GEOS-4386
                 URL: http://jira.codehaus.org/browse/GEOS-4386
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1-beta3
            Reporter: Senthilruban Puvanendran
            Assignee: Justin Deoliveira
Currently i am using GeoServer in production environment where tomcat running on port 8080 and with iptables, external port 80 requests are forwarded to port 8080 to access tomcat. Every one using GIS application or Geoserver will be using url with port 80 access as it is only accessible. Everything works fine. However in Geoserver demo request section, i have added few customized demo requests to generate shape files based on conditions, those are resulting HTTP response with 503 error code.
Reason for that, in the demo request page, URL is loaded based on client browser access url which means url with port 80. However the request executed internally within geoserver, there port 80 is not accessible.
The possible fix is having optional parameter in demo request file to specify the url, when it is not there, get baseUrl from request as current way.
Currently i given workaround to manually modify the url as localhost:8080/geoserver/wms to access.
If you are fine with above fix, i can provide the patch as familiar with codebase.
