[Geoserver-devel] [jira] Created: (GEOS-4391) WCS configuration submit throws java.lang.ClassCastException error.
                 Key: GEOS-4391
                 URL: http://jira.codehaus.org/browse/GEOS-4391
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-RC1
         Environment: solaris 11, JVM Sun Microsystems Inc.: 1.6.0_22 (Java HotSpot(TM) 64-Bit Server VM)
            Reporter: Greg Yetman
            Assignee: Andrea Aime
When changing the configuration of the WCS on the WCSAdminPage, hitting the submit button throws the error below, and the changes are not saved. Hitting the submit without changing the default configuration values throws the same error.
org.apache.wicket.WicketRuntimeException: Exception 'java.lang.ClassCastException: java.lang.Double cannot be cast to java.lang.Long' occurred during validation org.apache.wicket.validation.validator.MinimumValidator on component 15:form:maxInputMemory
  at org.apache.wicket.markup.html.form.FormComponent.validateValidators(FormComponent.java:1622)
  at org.apache.wicket.markup.html.form.FormComponent.validate(FormComponent.java:1201)
  at org.apache.wicket.markup.html.form.Form$23.validate(Form.java:2161)
  at org.apache.wicket.markup.html.form.Form$ValidationVisitor.formComponent(Form.java:173)
  at org.apache.wicket.markup.html.form.FormComponent.visitFormComponentsPostOrderHelper(FormComponent.java:441)
  at org.apache.wicket.markup.html.form.FormComponent.visitFormComponentsPostOrderHelper(FormComponent.java:428)
  at org.apache.wicket.markup.html.form.FormComponent.visitFormComponentsPostOrder(FormComponent.java:400)
  at org.apache.wicket.markup.html.form.Form.visitFormComponentsPostOrder(Form.java:1233)
  at org.apache.wicket.markup.html.form.Form.validateComponents(Form.java:2153)
  at org.apache.wicket.markup.html.form.Form.validate(Form.java:2133)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:1005)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:955)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
  at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
  at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
  at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
  at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
  at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
  at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
  at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
  at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
  at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
  at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
  at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
  at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
  at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
  at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:769)
  at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:698)
  at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:891)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
  at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.ClassCastException: java.lang.Double cannot be cast to java.lang.Long
  at java.lang.Long.compareTo(Long.java:34)
  at org.apache.wicket.validation.validator.MinimumValidator.validate(MinimumValidator.java:50)
  at org.apache.wicket.markup.html.form.FormComponent.validateValidators(FormComponent.java:1612)
  ... 165 more
