[Geoserver-devel] [jira] Created: (GEOS-4395) Allow a generic JS directory to webDispatcherMapping filePublisher
                 Key: GEOS-4395
                 URL: http://jira.codehaus.org/browse/GEOS-4395
             Project: GeoServer
          Issue Type: Improvement
            Reporter: Alessio Fabiani
            Assignee: Alessio Fabiani
The proposal is to insert another key, like for instance
<prop key="/js/**">filePublisher</prop>
into the webDispatcherMapping properties in order to allow external plugins to add more JS libraries to GeoServer without the need of modifying the applicationContext.
Using maven-war-plugin overalys is possible to merge WARs in order to easily extend GeoServer GUI capabilities with more stuff.
Maybe also an img folder would be useful.
