The SLD_BODY input stream is using a InputStream implementation with serious non-ascii issues.
Key: GEOS-440
URL: http://jira.codehaus.org/browse/GEOS-440
Project: GeoServer
Type: Improvement
Components: WMS
Versions: 1.3.0 RC4
Environment: All
Reporter: Magne Skjeret
Assigned to: Gabriel Roldán
Attachments: GetMapKvpReader.java
When adding the recieved SLD_BODY string to the geotools' SLDParser a InputStream is created as input to the parser.
The current implementation is using a StringBufferInputStream.
This stream has been decprecated by sun due to its issues in streaming non-ascii chars.
http://java.sun.com/j2se/1.5.0/docs/api/java/io/StringBufferInputStream.html
I have changed the code to use ByteArrayInputStream instead, which handles this properly.
For more information on JIRA, see:
